Activity Forums Maxon Cinema 4D SIMPLE AXIS ? (probably)
  • SIMPLE AXIS ? (probably)
    Posted by Robyn Rhodes on October 25, 2011 at 9:21 pm
    I have an object which, on the X axis says it’s Zero degrees in the Coordinates manager. But the object is not aligned to the Zero degrees of the world. How do I keep the object axis at 0 degrees, but also realign it with world Zero?
    I know this is probably 101 something, gotta start somewhere. Thanks!
    Robyn
    I’m only half the thing I say I am, the other half are me.
    Brian Jones replied 14 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    October 26, 2011 at 2:12 am
    pre-13 use the Object Axis tool to modify the axis without affecting the object, in 13 it’s the command Enable Axis Modification
