Activity Forums Adobe Premiere Pro Simple Audio Issue
  • Simple Audio Issue
    Posted by John Watts on April 16, 2019 at 6:07 pm
    From the stupid question department:
    I don’t do a lot of audio work in Premiere, but, this is so simple it really makes me feel less than intelligent!
    The latest, v13.1, easy sequence and laying some music down on audio track 3. The music is in stereo from the source monitor, but, mono when played from the timeline, both in sound and vu meters. Checking and rechecking settings it would appear all is set for stereo playback, but, it’s not happening.
    What am I doing wrong?
    THX
    John Watts
    Premiere Pro Version 12.1.2 Build 69
    2017 iMac (Retina 5K 27 inch) 1TB SSD
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
    Graphics AMD Radeon R9 M395X 4096 MB
    macOS Mojave 10.14
    John Watts replied 7 years, 5 months ago 2 Members · 2 Replies
  • Robert Withers
    April 17, 2019 at 6:34 pm
    Does it look like stereo on the timeline? Pr Pro has something they call a stereo track which will show two waveform patterns in the timeline. Or do they call it “dual mono”? I have a stereo track that was imported from FCP onto two mono tracks. You should be able to send the tracks to a submix bus that would play them as stereo, if they are not a stereo track on the timeline. I’m sure there are more buttons and settings that would apply.
    Cheers,
    Robert
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • John Watts
    April 17, 2019 at 7:10 pm
    This issue has been solved.
    When I made a new sequence, the 4 audio channels are default “mono”.
    Upon adding a new track it defaults to “standard”, which is stereo.
    Moved the music to the “standard” track and it is in stereo as it should be!
    Knew it had to be something simple.
    John Watts
    Premiere Pro Version 13.1
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
    macOS Mojave 10.14
