Activity Forums Adobe After Effects Simple Animation question…..
  • Simple Animation question…..
    Posted by Scott Ratner on February 3, 2009 at 8:14 pm
    I cannot believe I am having this problem, basically I take a layer in 3d set first keyrame with the layer in negative z space basically behind “camera”… then move 5 frames and bring the layer into view so it basically flies by camera, settles in the middle of the screen then i move far ahead in time and just set the z keyrame a bit further away… then 5 frames and set the z value really high and faade it out. So basically I want the title to fly in, drift slowly into the distance very slowly, while it is up so it is not static, then at the end fly into the distance and fade, the problem is when i set the keyrames i find that the layer behaves wrong and it drifts toward the camera before zooming off…. not sure this is making sense. its is a super simple animation, and i am stumped.. I can try and elaborate if needed… i think
    Anyone ?
    Scott Ratner replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
