Activity Forums Adobe After Effects Simple 3D Ball
  • Simple 3D Ball
    Posted by Michael Wilfong on September 30, 2006 at 6:20 pm
    I need to create a 3D Softball Spinning…without using a higher end 3d program, can I build that look inside AE alone…no zaxwerks! Just After Effects.??? Thanks in advance.
    M.W.
    Steve Roberts replied 19 years, 11 months ago 3 Members · 6 Replies
  • Mylenium
    September 30, 2006 at 6:29 pm
    CC Sphere is your friend.
    Mylenium
    [Pour Myl
  • Michael Wilfong
    September 30, 2006 at 6:34 pm
    Can I spin the CC spere 360 degrees and still see the “Back” side??
  • Steve Roberts
    September 30, 2006 at 6:35 pm
    Option 1: Use the CC sphere effect, under the “perspective” effects menu. First, create a comp twice as wide as it is tall, and draw the baseball skin on a rectangular layer that fits that comp. then drag that comp into your final comp, and apply Sphere to that comp-within-a-comp. You won’t be able to do fancy camera moves with it, because it doesn’t respect AE’s camera, so you’ll have to use the wussy controls within the effect. CC sphere is in the Cycore folder on the install disc. Hopefully you have a version of AE that includes it.
    Option 2: Make or find a baseball image (the circle with two curved lines) and drag it into your comp. Make the layer 3D, and set its layer>transform>auto-orient to orient towards camera. You’re making a disc that always faces camera, which sort of looks like a ball. But this works with AE’s 3D camera.
    Anybody else?
  • Steve Roberts
    September 30, 2006 at 6:37 pm
    Read my post below. You have to basically unwrap a baseball in your mind and draw that image on the long rectangular image which is then wrapped around the ball by CC sphere. This is called spherical texture mapping.
    You’ll have to make sure the ends of the map match, so you’ll see no seam on the ball.
  • Michael Wilfong
    September 30, 2006 at 9:51 pm
    I used option 1 and it worked great…thanks for the help!!! Always a pleasure.
    M.W.
  • Steve Roberts
    October 1, 2006 at 5:09 am
    Option 2 can be a really quick cheat, though. It’s good to keep it in mind. 🙂
