Activity Forums Maxon Cinema 4D Silver Bullet Error Tag
  • Silver Bullet Error Tag
    Posted by Phil Biggs on January 18, 2009 at 7:34 pm
    Hi chaps,
    I recently purchased Silver Bullet and have been running a few tests. I’ve set up a ten-pin bowling scene and I made the pins from lathe nurbs. However, Silver Bullet tags them with an error, saying they have ‘zero volume’. I’m not entirely sure what this means in terms of the simulation and therefore don’t know what to do to correct it. As far as I can see I have constructed them correctly and there is no problem with the geometry. Anyone have any ideas?
    Cheers,
    Phil
    Randy Johnson replied 17 years, 8 months ago 2 Members · 1 Reply
  • Randy Johnson
    January 19, 2009 at 9:13 am
    That tag comes up a lot for different reasons. Easy way to find out if it matters is to play the simulation. Sometimes you can just delete it and if it wont delete there is an issue….
    /randy
