Activity Forums VEGAS Pro sidechain compression?
  • sidechain compression?
    Posted by Terence Kearns on June 30, 2012 at 8:57 pm
    I would like to be able to use sidechain compression in my videos where I have narration with BG music. Does anyone know if this can be achieved in Vegas? I couldn’t figure out how to feed in a key signal to the standard compressor.
    If you don’t know exactly what I mean by sidechain compression, feel free to check out this video
    https://www.youtube.com/watch?v=41dwuQ6swE8&t=4m
    Dasz Szabó replied 13 years, 4 months ago 7 Members · 9 Replies
  • 9 Replies
  • Kevin Mccarthy
    June 30, 2012 at 10:02 pm
    Each audio track in Vegas has an effects button in the left window of the track. When you click the effects button a window opens up that will allow you to assign many different effectc. The compressor effect is fully adjustable and works well.
    The same options are available on the master audio track if you want to apply an effect to your final mix
  • Stephen Mann
    July 1, 2012 at 3:20 am
    While every track and bus has it’s own individual FX chain, I don’t think there’s any way to do a sidechain in Vegas. What were you trying to accomplish?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Mike Kujbida
    July 1, 2012 at 3:40 am
    It can’t be done directly in Vegas.
    One option is to buy Sidechain Compressor from db audioware ($90 U.S.).
    https://www.db-audioware.com/sidechain-compressor.html
    The other is to follow the steps outlined by user M_B in the following thread on the Sony Vegas forum.
    sidechain aka key-in compression – impossible?
  • Aleksey Tarasov
    July 1, 2012 at 10:28 am
    As an alternative, you can use scripting extensions, f.eg. – Voice Over
  • Terence Kearns
    July 1, 2012 at 11:32 am
    Thanks everyone.
    Mike, you’ve given me some good leads to chase up on with that thread. I already have a couple of good VST compressors with side-chain functionality. I’ll see if I can get one of those methods described, to be a viable workflow. The idea is that once I nail it, then I can keep using it. If it was just for a one-off project, then I would just use track automation. But I want to get something that will work well, and work reliably long-term. Would have been lovely if Sony implemented Re-Wire the way they did in Acid. I can easily access free/cheap DAWs (music software) which can host the audio without having to go through an error-prone export/import process.
    If I can sort something out, I’ll post a video tutorial or something.
    maybe track/channel architecture and rewire should be on the requested features list.
    Thanks again.
  • Terence Kearns
    July 1, 2012 at 11:36 am
    “As an alternative, you can use scripting extensions, f.eg. – Voice Over”
    This definitely looks like it will do the job. Would be good if I could just purchase this tool at a cheaper price. I can look at the rest of the Vegasaur suite, but that will take some time which I don’t have right now.
    Thanks for the solution. Much appreciated.
  • Aleksey Tarasov
    July 1, 2012 at 11:56 am
    You can freely use Vegasaur within 30-day trial period
  • Edward Troxel
    July 2, 2012 at 1:41 pm
    Or the original tool that could do this – Excalibur
    Or the second tool that could to this – Ultimate S
    Edward Troxel
    JETDV Scripts
  • Dasz Szabó
    May 14, 2013 at 2:23 pm
    Sounds like you work for Sony….
