Activity Forums Square Box CatDV Sidecar files
  • Matt Babcock
    January 22, 2014 at 4:07 pm
    Hi Dougal,
    I’ve been following everything you laid out in your post with no success until we tried changing mymov.xml to mymov.mov.xml and suddenly CatDV started picking up the xml files. Nothing I read said it needed the .mov in the xml filename. It also won’t associate xml files after a file has been loaded unless unless they contain the .mov or have the media path listed.
    I’ll open up a ticket with you in a bit to talk more about this issue since while working it still feels a little iffy.
  • Bryson Jones
    January 22, 2014 at 5:41 pm
    Matt, I’ve never seen this but I’ve been monitoring this as it develops.
    Can you check that the .mov extension isn’t hidden in your OS? Just a weird wild guess but something to check.
    bryson
    bryson “at” northshoreautomation.com
  • Matthew Stamos
    January 22, 2014 at 11:34 pm
    Not sure it has been mentioned here but the xml side car file name needs to include the parent file extension.
    (file.mov) side car should be named (file.mov.xml)
Page 4 of 4
