Activity › Forums › Square Box CatDV › Sidecar files
Matt Babcock
January 9, 2014 at 5:32 pmWell it’s good to know that I at least got that part working correctly. I worked out a script to take an excel file and parse each row into an xml file so I can ingest our legacy data.
I do have User 58 already created so that shouldn’t be the issue. Any other ideas?
Dougal Matthews
January 9, 2014 at 5:44 pm -
Matt Babcock
January 14, 2014 at 7:34 pmMy xml files have been validated on another installation of CatDV so I do know it has something to do with this particular installation. Hopefully that helps someone come up with an idea.
Dougal Matthews
January 15, 2014 at 11:56 amhi Matt
have you got the other import options like import non media files and recursively search sub directories etc turned on as in my screenshot in the previous post ?
cheers dougal
Improvise Adapt and Overcome
Matt Babcock
January 16, 2014 at 5:42 pmHi Dougal,
I do have everything in your screen shot selected including the import all types of documents and recursively search options.
Matt Babcock
January 16, 2014 at 5:45 pmThis week I tried setting up a watch folder to put both the xml and the video file and it imported them as separate assets but it did at least apply the metadata in the xml file to xml asset just not the video one.
Dougal Matthews
January 21, 2014 at 1:40 pmhi Matt
for sidecar files to work correctly CatDV expects to import the files at the same time so you need to have
mymov.mov and mymov.xml in a folder together BEFORE you can import them
you cant bring in the sidecar xml at a later date and expect catdv to populate metadata from it to an existing media asset the worker behaves i nthe same way the xml needs to be present with the media file and have the same file name before import
if this is still not working for you please can you raise a support ticket with support@squarebox.com so we can look in to this for you further
if you could summarize the steps you take with screenshots of the steps any error messages and send this to us along with the catdv logs we will take a look and see if we can help you get this working
to export logs see https://www.squarebox.com/exporting-logs-to-support/
thank you Dougal
John Heagy
January 21, 2014 at 3:04 pm[Dougal Matthews] “for sidecar files to work correctly CatDV expects to import the files at the same time so you need to have “
The common way of dealing with files arriving at different times into a watch folder is a setting that watches for two matching file named files before an action is triggered. This is a feature I would welcome.
John
Dougal Matthews
January 21, 2014 at 3:07 pmhi John
i’ll put this forward as a feature request for consideration for inclusion in future builds
thank you dougal
