Activity › Forums › Adobe Premiere Pro › Side scrolling / constant motion effect
  • Side scrolling / constant motion effect
    Posted by Rose Lee on July 26, 2017 at 4:35 am
    Hello,
    I am trying to achieve the effect used in this video in Premiere but so far haven’t been able to get it right:
    https://vimeo.com/91565944
    I’ve tried using the Push transition but it isn’t quite right. I am looking for my clip to be constantly moving horizontally, cascading into the next clip, with no stops in between, so I can make a loop. Anyone know how to do this in Premiere?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Daniel Waldron replied 9 years, 1 month ago 2 Members · 1 Reply
  • Daniel Waldron
    July 26, 2017 at 1:00 pm
    You could keyframe the x-axis position on one clip and the copy and paste the motion attributes to the rest of the clips. Once you have one or two lined up correctly in your sequence, in theory it should go rather quickly.
