Activity › Forums › Adobe Premiere Pro › Side by Side Images
  • Side by Side Images
    Posted by Brian Finifter on June 1, 2005 at 12:37 am
    My friend and I (my friend being the one who uses Premeire) are trying to export an animatic alongside the finished movie product in 6.0. My first question is how does one put two complete frames side by side and not in a split frame effect?
    Brian Finifter replied 21 years, 3 months ago 2 Members · 3 Replies
  • Steven L. gotz
    June 1, 2005 at 3:17 am
    What is the playback method? If you create a project with the correct dimensions, you can do anything you want. But two 4:3 frames do not fit into one 4:3 frame without making each one 50% of it’s original scale.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Brian Finifter
    June 3, 2005 at 1:30 am
    It’s for web delivery. We’ve adjusted the canvas to be wider, allowing space enough for both images and used the motion settings to line them up side by side. We’ve gotten, by trial and error, the placement to just the way we want it and it looks perfect in the little preview area inside the table. The problem is when we click OK to actually apply the effect, everything ends up distorted. The image on the left takes up about 20% of the frame, while the image on the right is stretched out of proportion to cover the rest. It looks good in the preview, so what’s the deal?
  • Brian Finifter
