Activity Forums Adobe Premiere Pro Shuttle Pro Macro Issue that’s been bugging me for 4 years…..
  • Shuttle Pro Macro Issue that’s been bugging me for 4 years…..
    Posted by Jan Janowski on November 1, 2016 at 12:30 pm
    This problem only occurs when I use the Macro’s in Shuttle Pro V2. I brought it up to Shuttle Pro’s attention 4 years ago, and they’ve been avoiding it since then…. All versions of their software drivers have this problem.
    I created a macro for a key that basically does the following:
    from the CTI on the timeline…. Switches to Full Screen Cinema Display, moves CTI back 3-4 seconds on the timeline, and hits play…
    It’s a really nice feature…. as it shows you 3-4 seconds before your CTI in the Full Screen Cinema mode… Hit it a second time and your back to edit mode!
    The problem as I discovered 4 years ago, was I had to add 200ms of delays to get the macro to work properly…. Otherwise it did strange-uncalled for operations. I did get it going by using delays to isolate other functions….. and thought I was done….
    Except that this Macro only works on single timeline sessions…. If you attempt to use it on a 2 or more timeline PPRO Session, the macro moves from one timeline layer to another….. which wasn’t in the macro commands that I programmed!!
    It is this part…. the moving to another timeline layer, that I contacted the Shuttle Pro people about 4 years ago….
    If I do the keystrokes manually, then it works without an issue…
    There has been plenty of apologies, and not much else in 4 years… I have stayed at PPRO CS6 and never went further…. but others have told me this problem is on later CC versions as well…
    In case someone has a Shuttle Pro V2 and would like to try the macro here is the step by step contents of that macro:
    1. 200ms delay
    2. Shift+4
    3. 200ms delay
    4. CTRL+`
    5. 200ms delay
    6. Shift+Left Arrow
    7. Shift+Left Arrow
    8. Shift+Left Arrow
    9. Shift+Left Arrow
    10. Shift+Left Arrow
    11. Shift+Left Arrow
    12. Shift+Left Arrow
    13. Shift+Left Arrow
    14. Shift+Left Arrow
    15. Shift+Left Arrow
    16. Shift+Left Arrow
    17. Shift+Left Arrow
    18. 200ms delay
    19. L
    Any comments/solutions, or other macro stories will be appreciated….
    Jan Janowski replied 9 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
