Shure VP 88
Posted by Jim Costa on March 28, 2007 at 12:49 amI am being advised that a Shure VP 88 is the way to go for voice over work. Does anyone have any experience with this mic?
Thanks in advance,
JimRodney Morris replied 19 years, 4 months ago 4 Members · 3 Replies -
Ty Ford
March 28, 2007 at 1:58 amYes I do. It’s a curious choice for a VO mic.
My review of the VP-88 is in the Online Archive in the Mic Reviews folder.
Regards,
Ty Ford
Ty Ford’s “Audio Bootcamp Field Guide” was written for video people who want better audio. Find out more at https://home.comcast.net/~tyreeford/AudioBootcamp.html
or https://www.tyford.com
Download Ty Ford’s “Existential Boogie” from iTunes now. -
Will Salley
March 28, 2007 at 4:22 amI have one. It’s a M/S stereo mic with a built-in matrix so it will output a L/R signal. Being a M/S mic, it could be used as a mono VO mic using the front element. However, I could think of about two dozen models that would work better and many of them are less expensive. The VP 88 has a lot of self-noise, which is multiplied (x2) when run in stereo mode.
Some VO mics I like are:
AKG 414 – my fave for vo
AKG C3000 – affordable but very useable for voice
EV RE-20 – sometimes boomy but legendary
Neumann TLM-49 – warms up tiny voices wellI’ve also read very good things about the M-Audio Sputnik but don’t have any personal experience with this mic.
System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
Rodney Morris
May 18, 2007 at 6:07 pmI’ve used the VP-88 in the past for field stereo recordings, but never as a VO mic. Doesn’t mean it can’t be done, but there are much better choices for vo mics.
The AKG C414 is good mic, which I used for years until I tried the Neuman TLM103. However the 103 lacks pickup pattern flexibility (cardioid only) and is a bit too sibilant for many female voices. Some of the best VO I’ve heard was recorded using a Sennheiser MKH416 (overhead mic placement). Heck, in a pinch, you could even use a Shure SM57 (with windscreen) and get very acceptable results.
