Activity › Forums › Adobe Premiere Pro › Shrink down a video clip into a separate file
Posted by David Saunders on March 24, 2017 at 10:27 amLooking in my lynda.com classes I can’t figure out how to do this….
I have a source video file that is say 5 minutes long but the only piece that is usable is just a 1 minute segment.
How would I pair down the file to what I need making a sub file that is smaller?
And thanks again to everyone, Your help is greatly appreciated.
-David
David Saunders replied 9 years, 6 months ago 4 Members · 5 Replies -
Tero Ahlfors
March 24, 2017 at 10:51 amImport the file, open it up in the source monitor, mark in and out for the bit you need and then export it out.
David Saunders
March 24, 2017 at 11:40 amOk great that makes sense
What setting do I click on the export to keep the same file characteristics?
Say the source was shot 4k 30fps on a Sony ax100
Thanks again
David
Jeff Pulera
March 24, 2017 at 2:03 pmHi David,
I tend to do my trimming right on the timeline. Use the Razor tool to place a cut where you want to start clip, then right-click on that first portion (before the cut) and select Ripple Delete. Then cut again where you want to end, then just select and delete that end part. Many ways to accomplish the edits. There’s also Mark In/ Mark Out then Lift or Extract, and those tools are available in the Program Monitor window.
As for export, where is the clip going? For myself, I may shoot 4K at times, but am not delivering 4K to my viewers – will export as 1080p or 720p. Most people are not set up to play/view 4K, that’s my opinion.
Exports for delivery (either for online or thumb drive, etc.) are usually H.264 – this is pretty universal for playback on Mac, PC, online, etc. and provides an .mp4 file format.
Before you even start editing – important to choose a proper Sequence Setting for the footage. If clip is in the Project Bin, you can right-click and select New Sequence from Clip. Then the sequence will match the source.
Jeff Pulera
Safe Harbor Computers -
Sergei Azarov
March 24, 2017 at 2:04 pmThe best way is to use VirtualDub. It can trim and split video without render (use direct stream in video options).
If your source video has non-support container (like mp4), then use something like SolveigMM Video Splitter -
David Saunders
March 25, 2017 at 10:53 amHey Jeff
I totally agree with you that most my editing is done on the timeline.
But this was the case where the file I created was HUGE and in the end all I needed was only 1/4 of it.Thank you very much for the answer!
-David
