Activity Forums Apple Final Cut Pro Legacy showing which clips in browser are being used
  • showing which clips in browser are being used
    Posted by Eugene Constable on November 12, 2008 at 12:19 pm
    Hi there
    Is there a function in FCP that allows you to see which clips in you browser are being used in a sequence and in which sequence?
    Similarly to the ‘reveal in composition’ feature that you get with the project window in After Effects.
    Also I used to use Incite ( unknown non linear edit system…) which was generally v slow and a bit rubbish but did have one or 2 cool features that I miss. such as being able to reveal all the clips in your browser that werent being used – can you do this in FCP?, I cant see it anywhere…
    thanks in advance!
    Eugene
    Jerry Hofmann replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 12, 2008 at 1:16 pm
    Select a sequence, then type cmd+f… you can use this to find clips not used in the sequence.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
