Activity Forums Adobe After Effects Expressions showing virtual cameras in other compositions
  • showing virtual cameras in other compositions
    Posted by David Denker on May 31, 2010 at 8:02 pm
    Hey guys, sorry for my bad english i’m german
    my setup: rearprojection wall (behind the band) 50″ plasma on the left and the right of the stage (upright)
    I want to show my animations on all 3 screens i will stream the stuff with a matrox triple head. (so i need a video from after effets which ist 3840×720)
    my problem: how do i prepair my compositions best to get a patially effect in my animations. for instance the amplitude of a heart beat monitor starts on the right plasma, goes over the projectionwall and disappears in the right.
    my idea: one composition with the animation in 3d space, 3 cameras which are on the same line and border each other, so i can controll what each screen shows of the animation. but how do i export the 3 different camera perspektives of the composition simultaneously?
    in the 2dn composition (3840×720) i want the images of each camera the two upright cameras (because of the upright plasmas) will bei rotated about 90° so i kan export the video in this resolution and have just to put the plasmas upright an everything “would” be fine.
    is there any expression to stream the video of a camera in another composition.
    thanks for your help.
    david
    Filip Vandueren replied 16 years, 3 months ago 2 Members · 3 Replies
  • Filip Vandueren
    June 1, 2010 at 6:33 pm
    Hi David,
    there’s no need for expressions or 3D cameras, but it does require some careful planning.
    First thing you need to do is create a comp “cropping setup” that visually represents the setup how it is going to look, this will probably not need to be as wide as 3840*720 because the two plasmas are much smaller than the projection screen, yes ?
    Something like this:
    Make sure the spacing and scaling of the 3 screens is as close to how it will end up in reality.
    I started with a 2000 x 720 comp, and placed a solid of 1280*720 at the center.
    I duplicated this solid twice and rotated, scaled and positioned them untill it looked OK. (it’s important that you start from a 1280*720 solid, even if the plasma’s are much smaller)
    I placed a movie on top using “Preserve Transparancy” to preview how the cropping would look. (and some texts just for labeling this now)
    I named the solids “crop 1-3”.
    You should do your animation in another composition of this size, and visualize how the cropping will appear by replacing the movie-layer (4) with that precomp.
    Once your animation is done, we are going to create a new Comp: “Uncrop”
    This comp should be 3840*720, it is your final output.
    Create three Solids of 1280*720 and place them perfectly side by side. (hold down command-shift so they snap to the edges of the comp). They will end up at positions:
    [640,360] [1920,360] and [3200,360].
    name them left to right: mask 1, mask 2, mask 3
    now drag the Comp “Cropping setup” into this comp, and duplicate twice so we have three copies.
    name the first copy “uncrop 1” and position it at the same pos as mask 1: [640,360]
    Now, we will do the reverse transformation of what we did to the solids in step 1.
    my solid “crop 1” had:
    position: [180,360]
    scale: [40,40]
    rotation: -90°
    first: anchor-point and position are the reverse of each other, so I’ll just enter [180,360] as the anchorpoint of “uncrop 1”
    2nd, the reverse of a 40% scale = 10.000/40 = 250% scale
    3rd the reverse of -90° rotation is of course +90°
    Done. Place the “uncrop 1” layer underneath “mask 1” layer and enable TrackMatte: Alpha Matte “Mask 1”
    For Uncrop 2 (which was unscaled, unrotated, and centered in my example) I end up with:
    position [1920,360] (same as mask 2)
    anchorpoint: [1000,360] (the position of layer “crop 2” in the “Cropping setup” comp)
    scale= 100
    rotation= 0°
    Again, place underneath Mask 2 and apply track matte
    Finally do the same for copy 3…
    here’s my endresult:
    I hope that was clear.
  • David Denker
    June 1, 2010 at 10:34 pm
    Right, the two plasmas are much smaller.
    Oh man, i could kiss your feets. Your understood exactly what I wanted.
    The idea ist actually very easy, but i didn’t even start to think about that there might bei such an easy way i was just focused on cameras and expressions 😀
    Thank you very very … very much for this detailed tutorial.
    David
  • Filip Vandueren
    June 2, 2010 at 12:31 am
    You’re welcome.
    I did think of a downside:
    You may want to enable “collapse geometries” on the two Plasma uncropped layers:
    in my example they were scaled up 250%, so that will mean some loss of quality.
    You can regain some of that quality (especially if your footage is vector-stuff) but the only way to have the plasma cutouts razorsharp is to have the original animation at a much higher resolution.
    I tend to not worry about that since spectators are going to stand pretty far away from the plasma’s so they won’t really notice a bit of pixilation/blurryness.
    But just so you know…
