Activity Forums Adobe After Effects showing only through lens flare
  • showing only through lens flare
    Posted by Mike Stern on January 15, 2010 at 12:10 pm
    Hey, I made a lens flare using “knoll light factory”, and i’m trying to make an effect in which Im putting my lens flare behind a picture (in 3D ofcourse), and i want to see the lens flare itself, and only the parts of the picture which are exactly in front of the lens flare.
    I figured i should use a specific blending mode on the picture, but the only one that has a similar result is “silhouette luma”, but it shows the picture in black and white and not in color.
    What do i do?
    Thnx ahead
    Mike Stern replied 16 years, 7 months ago 2 Members · 3 Replies
  • Mike Stern
    January 15, 2010 at 4:14 pm
    Well, when i lower the opacity of the picture, i can indeed see the lens flare behind it, although i still see parts of the picture which are’nt in front of the lens flare, but i want to see only the ones in front of it..
    Masks will not be any good unless i want to work really hard, because if i want to animate the flare so it moves behind the pictures, i’d have to manually key frame the masks..
  • Michael Szalapski
    January 15, 2010 at 5:09 pm
    If you duplicate your lens flare layer and use it as a Luma Matte for the picture layer does that do what you want?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Mike Stern
    January 15, 2010 at 10:55 pm
    Actually it does! I just didn’t think about duplicating the lens flare layer!
    THANKS!
    Mr. LaRonde, i guess sometimes slackers are just people who are not yet to find the easy solution.. 🙂
