Activity Forums Apple Final Cut Pro Legacy showing markers on an exported clip
  • showing markers on an exported clip
    Posted by Steve Harrington on November 12, 2010 at 1:37 am
    How can I show markers (specifically edit/cut markers) in an exported clip. I know they exist because they show up in compressor, however I cannot get them to show in fcp when I re-import the clip? any suggestions?
    Diego Buenaño replied 15 years, 9 months ago 3 Members · 4 Replies
  • Steve Harrington
    November 12, 2010 at 4:47 am
    could I export and edl from my source project and have final cut read it to help mark the cut points?
  • Andreas Kiel
    November 12, 2010 at 11:01 am
    In QT Player Pro go to the properties (cmd-j) and switch the text (chapter) track to visible. The marker names will be displayed above the video.
    Andreas
  • Andreas Kiel
    November 12, 2010 at 6:15 pm
    You even can go further and export the text track as text, add your comments (without changing the timing) and re-import again. You may change the chapter after that as well.
    Andreas
  • Diego Buenaño
    November 12, 2010 at 6:27 pm
    Try CatDV. You can make markers in CatDV and be seen in FCP or viceversa.
    Best
