Activity Forums Adobe Premiere Pro Showing film on projection system – color and look way off.
  • Showing film on projection system – color and look way off.
    Posted by Anthony Susnick on August 27, 2013 at 2:13 am
    I just got back from testing my film at a venue I will be showing it at next week. It was shown on a large projection system. The laptop monitor showed the film perfectly but on the screen the picture was a little vertically squished and extremely dark in places and the colors – like faces were very red.
    I assume this is all about color correction and broadcast colors. What are my first steps to resolving this? The film looks great on my TV. Thanks!
    Chris Murphy replied 13 years ago 6 Members · 5 Replies
  • Shane Ross
    August 27, 2013 at 4:33 am
    No…it’s about the projector. Looks fine on your computer, fine on your TV, but not on the projector.
    Shane
    Little Frog Post
  • Morten
    August 27, 2013 at 6:19 am
    Many projectors can change between colour spaces. You should look for a setting called “sRGB” or something like “FILM”.
    – No Parking Production –
    2 x Finalcut Studio3, 2 x Prod. bundle CS6, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid…. and FCPX on trial
  • Jeff Meyer
    August 27, 2013 at 6:49 am
    Anyone know the last time a new lamp was dropped into the projector?
  • Chris Borjis
    August 27, 2013 at 6:00 pm
    or the last time it was calibrated for that matter?
    I’ve seen many ghastly presentations based on projector
    settings being out of whack.
    unfortunately most venues but the highest end ones will
    likely be the case.
  • Chris Murphy
    August 31, 2013 at 7:12 pm
    I think the responses thus far are heading in the right direction, it’s probably the projector. Have a tech go through the projector’s OSD menu, and video or photograph all of the current settings (cell phone video is fine, do whatever is easiest). Then find a setting to reset everything. Sometimes this is a global reset, sometimes it’s per page, sometimes it’s just for color. I’d reset everything. Then play your video and tweak the settings needed from there. sRGB is a reasonable assumption as it uses the same RGB primaries as Rec 709 for broadcast. But manufacturers are all over the map on hitting the sRGB primaries, and the tone reproduction curve.
    If it’s still really bad, well, put up some color bars and see if this is a white point problem, or the primaries are just wrong, or what. If it’s an old projector it’s possible the RGB filters are decaying, and there’s not much that can be done about that. Get it as bright as you can and the white point reasonably neutral. The next step would be some way to characterize the projector, and then do a 3D transform of every single pixels on-the-fly to account for the difference between sRGB and the projector – although I can’t tell you what can do such on-the-fly 3D transforms, maybe someone else knows that. Otherwise the alternative is to re-render the whole film and bake the transform into what’s effectively an projector specific video, and I think Premiere can do that these days with ICC profiles.
