Activity › Forums › Adobe After Effects Expressions › Showdown counter with expression
  • Showdown counter with expression
    Posted by Daniel Drummond on May 7, 2021 at 8:58 pm
    <pre data-placeholder=”Tradução”>Good afternoon guys<pre data-placeholder=”Tradução”>I’m having trouble trying to slow down this counter. As I have very large numbers in a few seconds the script goes from 0 to 1,000,000 very quickly. I wish I could have a better control on speed, they could help me, because I’m not getting it.
    s = “” + Math.round(effect(“Point Control”)(“Point”)[0]);
    s.replace(/\B(?=(\d{3})+(?!\d))/g, “.”);
    Tomas Bumbulevičius replied 5 years, 4 months ago 3 Members · 2 Replies
  • Andrei Popa
    May 8, 2021 at 7:24 am
    Select your layer and press U. You should see a Point Control property. Modify the values/position of this property for a different speed.
  • Tomas Bumbulevičius
    May 8, 2021 at 9:50 am
    Hey Daniel, most likely solely through graph editor and keyframes editing you won’t be able to slow down things.
    For this reason, add additional keyframes with smaller incremental values in between, set them to be linear-type (no easing that counter won’t slow down when keyframe is reached), and it should be good to go.
