Activity Forums Zaxwerks Showcatcher not catching?????
  • Showcatcher not catching?????
    Posted by Rich Huxley on September 24, 2008 at 7:44 am
    Hi everyone, I am trying to put a 3d model of a golf ball being hit around a golf coarse (which are 2d video footage looked off) The 3d model of the ball is no problem I am using a flat plane also in Invigorator to chatch the 3d shodow,
    however before I switch the surface of the flat plane to the shadow catcher i see the shadow but when I change to the surface catcher surface
    I loose it
    I am using AF CS3 and Invigorator 4.3.2 on a Macpro 8core
    Any help would be very appreciated as I am starting to go a little crazy
    thanks
    rich
    Rich Huxley replied 17 years, 11 months ago 2 Members · 3 Replies
  • Rich Huxley
    September 24, 2008 at 12:04 pm
    sorry, I meant SHADOW CATCHER
  • Matt Rhodes
    September 24, 2008 at 11:01 pm
    Hi Rich.
    This is likely a bug.
    Try rotating your floor 180 degrees along the X axis.
    This will flip the floor to point in a direction that the Shadow Catcher can handle.
    Let us know if you have any other questions.
    Matt Rhodes
    Zaxwerks, Inc.
  • Rich Huxley
    September 28, 2008 at 9:43 am
    Hi Matt
    Thank you so much, Flipping the plane on the x axis 180 degrees has produced the shadow in shadow catcher mode
    cheers
    rich
