Activity › Forums › Apple Final Cut Pro › Show used range bug
  • Show used range bug
    Posted by Mark Morache on April 16, 2014 at 10:18 pm
    I like the used footage indicators in the browser. Believe it or not, I have been known to re-use shots I forgot I already put in the timeline.
    I noticed today that practically the entire 20+ minute clip was indicating that it was used, and my timeline is only 2+ minutes.
    I copied my sequence into a new timeline and started deleting clips until I found the culprit.
    Turns out it was a single freeze frame clip that I had created using the menu item “add freeze frame” or opt-F key. For some reason this caused nearly all of my footage to show up as used.
    Anyone else have this problem, or is there some way to avoid this that I’m not aware of.
    Thx.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
    Bret Williams replied 12 years, 5 months ago 2 Members · 1 Reply
  • Bret Williams
    April 17, 2014 at 2:28 am
    Here’s another. If the footage is contained in a compound clip, it’s invisible to the used clips function as well.
    Just like FCP 7. There was a “find used clips” command in legacy. It was a manual version of the automated process in X. BUT, if the clip was nested, then the command didn’t find it.
