Activity Forums DaVinci Resolve Show track v1 when a clip is on v2
  • Show track v1 when a clip is on v2
    Posted by Robin Erard on August 5, 2011 at 5:42 am
    Hello,
    I’m working for a splitscreen music video.
    Is there a way to show a clip on track v1 when there is a clip on track v2 (or v3…) ?
    Until now, I go to conform and active and desactive tracks. Is there a shortcut for that.
    Best
    Robin
    réalisateur, scénariste, monteur, étalonneur
    http://www.robinerard.ch
    Blase Theodore replied 15 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Rohit Gupta
    August 5, 2011 at 6:31 am
    You can use the UNMIX mode (next to clip/track)
  • Sascha Haber
    August 5, 2011 at 6:33 am
    I assume he wants to stay in the current edit, with sound and all.
    So I second the request, a function to jump the visible top track would be splendid.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Vladimir Kucherov
    August 5, 2011 at 7:31 am
    If unmix doesn’t work for whatever reason, here’s a hack idea:
    On clips you’d like to mute, create an new unconnected mode. Hook it up to the source image. Add an alpha output, and connect the node to that. Now, if you invert the key on that node it will make it transparent.
    You can either enable/disable that node to toggle the clip, or invert key on that node. Inverting key might be better because it won’t mess you up when doing enable/disable all on a grade.
    Not elegant but it should work!
  • Sascha Haber
    August 5, 2011 at 8:04 am
    That is clever, I like 🙂
    Oh Robin, do you need to play them or just look at the lower ones ?
    If so, just select the lower green block in the timeline.
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
  • Robin Erard
    August 5, 2011 at 9:29 am
    Hello,
    Thank’s all for your help.
    I need to play them. Then the idea of Vladimir is a good idea.
    But, that’s true, it could be good to be able to do that in “clip” mode with a special shortcut.
    Best
    Robin
  • Michael Stirling
    August 5, 2011 at 12:11 pm
    you could do this hack in track mode, giving a quicker mute whole track than going to the conform page or per clip muting
    MUTE and SOLO track buttons in the color page would be nicer though
    M
  • Blase Theodore
    August 5, 2011 at 6:51 pm
    Ha, nice Vlad!
