Activity › Forums › Apple Final Cut Pro Legacy › show software with backtiming???
  • show software with backtiming???
    Posted by E. Eric johnson iii on January 25, 2006 at 10:00 pm
    hep’ me, hep’ me… i be hyp-mo-tyzed!!!
    i’ve searched the archives to no avail… google has let me down…
    currently i’m working with a company that needs software that will back-time a show to 0. a similar program would be “iNews” or something like that; however, that’s big $ for a tiny operation. final draft av does not have back-timing.
    any ideas???
    e. eric johnson iii
    eric@lillcreates.com
    lill creates: founder/executive producer
    Water Channel: producer/virtual set operator
    E. Eric johnson iii replied 20 years, 8 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    January 26, 2006 at 4:05 am
    Countdown? is that what they need? like a backwards clock? Why software?
    Jerry
  • E. Eric johnson iii
    January 26, 2006 at 4:28 am
    unfortunately it’s not a countdown, it’s for show timing.
    if a show is supposed to be 30-minutes w/3 internal breaks of two minutes plus a terminal break of 2 minutes, then the show has 22-minutes of actual content in 4 segments. since content isn’t finite each segment varies in length but they must total to 22-minutes in the end.
    so the program starts at 30-minutes and each break & segment begins subtracting from the 30-minutes until it reaches “0.”
    it’s like a bulletproof excel sheet with jpegs being able to be shot around. show producers can slaughter an excel sheet. boy, i wish it were as simple as a countdown!
    anyone, anyone?? — bueller?
    e. eric johnson iii
  • Walter Biscardi
    January 26, 2006 at 4:48 am
    Just use a time calculator. That’s what we used to use at CNN and production companies I work with use them all the time.
    https://www.markertek.com/SearchProduct.asp?item=TMR%2D1&off=1&sort=prod
    You can just type in the time segements of each of your shows and ensure that you’re hitting 22 minutes.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
    January 26, 2006 at 5:30 am
    thank you for the help & the link. that’s probably the route we’ll have to take.
    eric
    e. eric johnson iii
    January 26, 2006 at 8:18 pm
    it’s drop-frame, though the producers that use it wouldn’t know the difference. tv stations have been using a program like this for decades. it’s not complicated, just bulletproof for deadline live tv production. there’s really not much of a market for it unless you have large $’s i suppose.
    thanks for the inquiry and the help.
    eric
    e. eric johnson iii
