Activity Forums Adobe After Effects Show render speed in info panel
  • Show render speed in info panel
    Posted by Ferenc Van der velde on March 8, 2018 at 9:49 pm
    Quick question: How can I see the render speed while rendering. I can see the “Caching Frames 23 of 100” and “Rendering frame 23 of 100” in the info panel, but is there a way to see “Rendering @ 2fps” or something similar? Wasn’t this the case in previous versions of AE or am I just imagining that? I’m using AE 15.0.1.
    Thanks in advance!
    Ferenc Van der velde replied 8 years, 6 months ago 3 Members · 4 Replies
  • Walter Soyka
    March 9, 2018 at 8:17 am
    Ae reports playback frame rate in the Info panel. If you just start playback without caching or rendering first, you’ll get the effective render speed in frames per second (up to real-time).
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ferenc Van der velde
    March 9, 2018 at 9:48 am
    That did the trick! Thanks.
  • Carlos Aldana
    March 16, 2018 at 4:47 am
    I’ve never seen ‘Rendering at 2fps’ or something like that. But if you put more info (on the little down arrow), you can see the average time each frame is taking, and what layer is currently rendering.
    March 16, 2018 at 9:20 am
    Hmm, I can’t see more info under the little down arrow in the info panel. Turning caching off works though.
