Activity Forums Adobe After Effects Expressions Show/Hide properties with keyframes from an extension
  • Show/Hide properties with keyframes from an extension
    Posted by ali kim on November 12, 2024 at 8:52 am
    I’m trying to write an extension that can show/hide properties with keyframes.
    The most relevant piece of code goes like this:
    var cmdStr = ‘Reveal Properties with Keyframes’;
    executeCommand(cmdStr);
    function executeCommand(cmdStr) {
    var cmdId = 0;
    cmdId = app.findMenuCommandId(cmdStr);
    if (cmdId == 0) return cmdId;
    app.executeCommand(cmdId);
    return cmdId;
    When called the first time, it works and opens keyframed props, but when called again, it opens all props of the layer.
    I got an advice on Adobe Forum to change executeCommand function like this:
    var cmdId = 0;
    // RevealAllModifiedProperties
    app.executeCommand(2771);
    return cmdId;
    this doesn’t fix the problem because double 2771 call hides all props and original call opens them again, so this code can only show props but not hide them.
    Anyway, I tested both versions, below if the full code of the extension and how it works.
    Does anyone know how to make a switch to show/hide keyed props?
    ali kim replied 1 year, 10 months ago 2 Members · 2 Replies
  • John Cuevas
    November 12, 2024 at 1:49 pm
    Is this any different that just selecting all layers and pressing “U” which reveals anything property that has a keyframe?
  • ali kim
    November 12, 2024 at 2:53 pm
    No, that’s exactly the functionality I’m trying to achieve, just from inside the extension, w/o pressing U.
