Activity › Forums › Adobe After Effects Expressions › Show/Hide Layers and Add to Encoder Script
  • Show/Hide Layers and Add to Encoder Script
    Posted by Aitor Canto on January 5, 2022 at 2:33 pm
    Hi all,
    I have got a multilingual project where there is a main footage and then 6 different languages with copy divided in 6 comps.
    I am looking to speed up my work with an action o script to export(add to encoder) the same comp with each language and add the language at the end of the Comp name. e.g. Comp_EN
    The process will be like this one.
    1- Show layer ES
    2- Add Comp to Adobe Encoder
    3 – Add “_ES” to the end of the Output comp filename.
    4 – Hide layer ES
    and so on with the others languages.
    If you can advise on this I’d be very grateful.
    Aitor
    Aitor Canto replied 4 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
