Activity Forums Adobe Premiere Pro show background in Titler
  • show background in Titler
    Posted by Randy Hess on August 26, 2013 at 1:30 am
    I am not able to see the video in the background when creating titles anymore. It had been working and maybe something got corrupted, I have no idea what is wrong.
    I have done the obvious by making sure “background” is unchecked and “show background video” is checked.
    This results in the title appearing on a black background. If I then uncheck “show background video” this results in the title appearing over the grey pixeled background.
    Suspecting the possibility of a corrupt preference somewhere I started the program holding down the shift+alt keys to restore defaults. This had no impact.
    Since this feature was working when I stared the project I am baffled as to why it has since failed.
    Premiere 5.5.2
    Windows 7
    HP machine
    Chris Paul replied 12 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Ann Bens
    August 26, 2013 at 10:14 am
    Are you sure you have the cti over a video in the timeline. Just asking.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Randy Hess
    August 26, 2013 at 1:49 pm
    I created a new project, with the same settings and the new project does not have this problem. So is there any way to create a new project and still keep my sequences and bins? Such as save project as…? Saving project under a new name does NOT work.
    Randy Hess
  • Steve Brame
    August 26, 2013 at 2:56 pm
    You can import an entire project into a new project, maintaining the structure.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID5 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Creative Cloud
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Randy Hess
    August 26, 2013 at 4:22 pm
    Great idea! I tried it, however still the same result, ugg!
    Since I imported the old sequences, however this helped me discover the problem had to lie in the sequence itself.
    I made a new sequence, copy & pasted the master sequence footage into it and viola!
    Problem solved.
    Randy Hess
  • Chris Paul
    January 7, 2014 at 4:53 pm
    Adobe did a “bug fix” 4 days ago and now background preview in the titler is completely disabled- does not work in any sequence, old or new, in any standard format. Will try some custom ones.
    Chris Paul
    POV
  • David Tan
    January 18, 2014 at 8:12 pm
    I also experience the same problem.. actually if u open the title tool and go back to the timeline and scroll your playhead it will update to your title tool.
  • Chris Paul
    January 20, 2014 at 5:53 pm
    That works- thank you!
    Chris Paul
    POV
