Activity › Forums › Maxon Cinema 4D › Show All Animated
  • Show All Animated
    Posted by Glenn Takakjian on February 25, 2007 at 8:53 pm
    There used to be a Show All Animated Option in the Timeline which showed… well … All objects and Tags that were currently animated with one click.
    Now it is just Show Animated which instead removes any non animated objects and tags. Is there a fast way to get all the animated objects and such to show up. I have to drag and drop from the Object manager. This can get time consuming when there are a lot of objects.
    I wish they would bring that button back.
    Also, has anyone nticed that version ten is not nearly as stable as previous versions. It crashes quite a bit. I’ve noticed it crashing when I sometimes try to change a color in the Layers Manager. Also when I’m in the Materials manager.
    TAK
    Glenn Takakjian replied 19 years, 7 months ago 2 Members · 2 Replies
  • Samir Kharchi
    February 27, 2007 at 12:42 pm
    sorry, I don
  • Glenn Takakjian
    February 27, 2007 at 10:01 pm
    Lets say you open up the time line… none of your objects or tags are in there. It is empty. In previous versions, If you hit the Show All Animated button, every object or tag in that project would appear in the timeline window. Then you could select and hide all you want.
    The Show animated button doesn’t do that. If you have an empty timeline and hit the button… it stays empty. It sort of works in reverse. If you have a whole bunch of objects and tags in the timeline, some of them have animated parameters and some don’t.. you hit the show animated button and all the non animated tags and objects dissappear leaving only those with animated parameters.
    At least that is whats happening on my system.
    TAK
