Activity Forums VEGAS Pro Should these rendering settings work right????
  • Should these rendering settings work right????
    Posted by Preston Mullins on July 24, 2010 at 12:32 am
    I was hoping you guys could check to see if these specs look okay for the web videos I made. I shot on Sony NXCAM, 1080p, 30fps.
    They said my last videos were jumpy, so I took the advice from some of you guys in other threads here, mainly John Rofrano, and I changed my settings. I was using ‘Animation’ codec, but now I’m using MPEG4, as John suggested. There’s just so many other settings in Vegas that I’m not sure of, so please take a look and let me know if this all jives:
    *Save as type: Quick Time 7 (*.mov)
    *Audio: 44,100 Hz, 16 Bit, Stereo, PCM
    *Video: 29.970 fps, 1920×1080 Progressive
    *Pixel Aspect Ratio: 1.000
    *Frame Size: High Definition 1920 X 1080
    *Frame Rate: 29.97000
    *Field Order: None (progressive scan)
    *Video Format: MPEG-4 Video
    *Compressed Depth: 24bpp Color
    *Quality: 100%
    *Data Rate: Unconstrained
    *Keyframe every (frames): 30
    Does anything look off here? John, if you are out there, heeeeeelp! Thanks for your time, guys.
    Preston Mullins replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
