Activity Forums Adobe After Effects Should the sequence be rendered before exporting it into Adobe After Effects?
  • Should the sequence be rendered before exporting it into Adobe After Effects?
    Posted by Elysa Underwood on January 17, 2012 at 10:31 pm
    Hey,
    I apologize for this very, very stupid question, but I’ve never worked with After Effects before and I’m freaking out here, cause I have to hand in a short movie in about 10 hours and if I do not,I am most definitely going to fail this particular class.
    So, I edited and cropped all the clips, I’ve added the music already and I just have to apply some effects and I’m done,but the problem is that when I export my sequence into After Effects, all videos I’ve cut and made shorter just appear the same way as before the edit, namely in full length. Before exporting the project I forgot to render it, could that be the problem ? If not, what should I do to have all clips in the edited length?
    Thanks in advance!
    Walter Soyka replied 14 years, 7 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 17, 2012 at 11:44 pm
    What are you using to edit the footage, and how you exporting it to AE?
    What is it that you actually need to accomplish in AE?
    Walter Soyka
