Activity Forums Adobe Premiere Pro Should I use the mpeg encoder? Encoding problem.
  • Should I use the mpeg encoder? Encoding problem.
    Posted by Shane on July 24, 2006 at 3:42 pm
    I recently shot some footage with a cheap sony camcorder (640×480, 30fps) and ive already finished the compositing, 3D work, and effects that I added to the footage. Now I want to burn this footage to a DVD. How should I render out the final footage? Should I use the mpeg encoder? I tried it once, but there was no audio? I think maybe I might need to find the AC-3 codec to hear it, but I am uncertain.
    What is the proper way to do this? The footage is not 720×480, so do I need to fix that in the advanced settings for the mpeg encoder?
    Any help would be appreciated.
    I am using Adobe Premiere 6.5.
    Mike Velte replied 20 years, 1 month ago 2 Members · 1 Reply
  • Mike Velte
    July 25, 2006 at 11:27 am
    The Mpeg encoder will handle the 640 to 720 thingy OK. It exports 2 elementary streams, one video (.m2v) and a AUDIO (.wav). That combination is what most authoring apps look for.
