Activity Forums Apple Final Cut Pro Legacy Should I use the CCIR 601 sequence setting for editing footage transfered from Beta to DVCAM
  • Should I use the CCIR 601 sequence setting for editing footage transfered from Beta to DVCAM
    Posted by Jack Pitzer on April 7, 2006 at 3:33 pm
    Greetings, Should I use the CCIR 601 sequence settinf for editing footage that has been transfered from Beta to DVCAM?
    There is a 6 pixel difference in Beta footage, so when viewed on a computer there’s a black border on the left side of the frame, which is what i’m trying to avoid.
    Any thoughts?
    Sincerely, Jack Pitzer
    Graeme Nattress replied 20 years, 5 months ago 4 Members · 3 Replies
  • Rich Rubasch
    April 7, 2006 at 3:56 pm
    The 6 pixel difference you mention is actually on the top and bottom…..there are 6 additional lines of video with CCIR 601 486 footage. DV and DVCPro50 along with MPEG-2 cut it down to 480. Should you use the CCIR 601 setting? It depends on which codec you will use for the final output. If you want to work in standard DV then use the DV setting (same if you use DVCPro50). If you want to use a 486 codec like Apple’s uncompressed 8 bit then you will set it up with the 486 CCIR 601 setting.
    It is codec dependent not source tape dependent.
    The black on the left side could have been caused during the dub from Beta if one of the deck’s sync was off a bit. There is a horizontal sync setting that could push the image to the left or right. This is not so unusual actually.
    But the 6 pixel difference is vertical not horizontal.
    Rich Rubasch
    Tilt Media Inc
  • Chris Poisson
    April 7, 2006 at 4:28 pm
    When you put DV footage in a D1 sequence, you should adjust it so that it has 4 of the extra black pixels on the bottom and 2 on the top.
    Have a wonderful day.
  • Graeme Nattress
    April 7, 2006 at 8:53 pm
    If you see black at the left or right, then that’s correct. Because analogue video can “move” around with sync and timebase errors, digital video was designed to record more to the left and right than actually would normally exist in analogue video to make sure that even with sync errors, nothing is missed.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
