Activity Forums Avid Media Composer Should I use SD offline format for HD project?
  • Should I use SD offline format for HD project?
    Posted by Leif on February 28, 2007 at 12:03 am
    I’ve been looking at the work flow for an Adrenaline HD project. Avid suggests down-converting HD to SD, editing in SD, decompose and re-capture at HD.
    This sounds fine but my question is; is this necessary? The media in my project will be DVCPROHD which, in FCP, edited just fine w/o having to recompress to an “off-line” format. Is this work flow for uncompressed HD only?
    Thanks for any advice.
    -Leif
    Leif replied 19 years, 6 months ago 2 Members · 2 Replies
  • Michael Phillips
    February 28, 2007 at 2:02 am
    It’s usually the workflow for projects that have more footage than storage for any given resolution. Capture as SD first, then recapture HD. If it is DVCPRO HD and you have the storage, then go for it.
    Michael
    anything 24fps
  • Leif
    March 1, 2007 at 2:07 am
    That makes sense.
    Thanks Michael.
    -Leif
