Activity Forums Apple Final Cut Pro Legacy Should I use FCP or Motion? Advice ASAP Please
  • Should I use FCP or Motion? Advice ASAP Please
    Posted by Joe Severino on August 18, 2010 at 3:31 am
    Okay I am working on some video (DV NTSC) and want to slow down the footage as well as steady the camera movement and am not sure which would give me better results and could use some of that awesome Creative COW knowledge.
    Should I go with the time remap feature and steady cam in Final Cut Pro or send the footage to motion and use optical flow and stabilize and either the video speed adjustment in the inspector tab or the time remap filter.
    This footage also will be sent to color for correcting and other stylize color correction. At the moment I have my sequence codec set to ProRes 422. Should I change it back to DV/DVCPRO or leave it set to ProRes 422?
    Thank you all so much for all your input. I (and my client) really appreciate it!
    Mac Pro 3.2 GHz Dual Quad Core
    14GB RAM
    NVIDIA 8800 GT
    Blackmagic Intensity Pro
    OS X 10.6.3 (Clean Instal)
    Final Cut Studio 3 (Clean Instal)
    Logic Studio (Clean Instal)
    Zak Ray replied 16 years ago 2 Members · 1 Reply
  • Zak Ray
    August 18, 2010 at 2:15 pm
    Optical Flow may produce better results for slow motion, but the Stabilize behavior is for absolute stabilization rather than “smoothing”. It depends on which you’re looking for. Either way, don’t expect spectacular results from DV footage if your footage is more than a little unsteady.
    ProRes is fine.
