Activity Forums VEGAS Pro Should I keep the same pixel aspect ratio
  • Should I keep the same pixel aspect ratio
    Posted by Andrew Turner on January 25, 2010 at 4:14 am
    Hi All,
    I shot my footage at 1920×1080 1.000 Square pixel. I’m now at the stage of exporting a Standard Definition PAL Widescreen. Should I set my pixel aspect ratio to the DV Widescreen setting of 1.4 or keep it at square pixel 1.00.?
    I’m a bit confused on if i need to keep the same pixel aspect ratio all the way through my project or do I change it depending on the delivery format?
    Thanks in advance.
    AT
    Andrew Turner replied 16 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    January 25, 2010 at 1:46 pm
    You should not change anything in your project. You simply render in the delivery format that you want and Vegas will do all the aspect conversions for you, letterboxing etc. as needed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Andrew Turner
    January 25, 2010 at 11:55 pm
    Thanks John, Greatly appreciated.
    Cheers
    Andrew Turner
