Activity › Forums › Apple Final Cut Pro Legacy › should i ever trust fcp item properties??
  • should i ever trust fcp item properties??
    Posted by Zeynep Ayguler on September 13, 2009 at 11:17 pm
    well..i most of the time prefer to believe in..but when field dominance is in question, i find it kind of inaccurate..i’m working on dvPal(lower field first) materials and in my case it is rather complex thing to handle field dominance from beginning to end..
    the issue is..fcp analyze field dominance correctly when i first time drop a footage to a sequence..but after some rendering operations from other apps or even from fcp itself, item properties says field dominance is upper..(i’m using interlaced lower field fist options just like my original footage and using quicktime uncompressed codec while rendering out from shake or AE)..
    actually i realize that rendering out different applications or changing field dominance settings while rendering doesn’t make any differences according to fcp’s item properties(on subject of field dominance)..i thought, it is maybe quicktime codec reordering fields..tried .avi..the same..
    so..i’m kind of disappointed for not being able to analyze my clips correctly into fcp..and asking for suggestions on this head..
    also..could you offer any software or method to analyze interlaced dv materials in extensive way??
    best,
    Z.
    Zeynep Ayguler replied 16 years, 10 months ago 2 Members · 2 Replies
  • Andrew Saliga
    October 23, 2009 at 8:23 pm
    Similar issue here. Sent some footage off for color correction and they’re saying it was given to them interlaced instead of progressive. I’m looking here judging by my eyes and it definitely doesn’t look interlaced.
    Unfortunately I don’t have a solution yet other than previewing in QT and making sure the deinterlace option isn’t checked as I scrub through areas of high motion.
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
  • Zeynep Ayguler
    November 21, 2009 at 1:19 am
    hello..thanks for the respond…that issue is remaining to being a mystery about fcp for me too…
    and..another strange thing is..as i mentioned in one of the previous article.. that some time ago i got across that passage while reading the Shake4 manual at p.197..(under field rendering settings passage)..and..it was written;
    • odd/1: Use this setting for video media with a field dominance of odd (counting
    from the top) first. This is generally the setting for PAL images. In Final Cut Pro, this
    setting is referred to as Lower (Even).
    so..is that mean PAL upper field first images is referred to lower(even) in final cut pro??.. i really can’t understand that relation..
    if anyone could explain,i really be glad..
