Activity Forums Adobe After Effects Should I crop images before editing them in AE to render fast?
  • Should I crop images before editing them in AE to render fast?
    Posted by Yousuke Tadokoro on January 30, 2013 at 3:48 am
    Hello. I am using AE CS6 win version.
    Right now, I am editing my animation in AE. I made the animation in photoshop using its timeline, and I rendered all images as a PNG image sequence with alpha channel. Size of the sequence is 1000 x 1000 pixel. And I imported those PNGs into AE, and put them into 500 x 500 pixel compositon.
    And I have a question, should I crop PNG images to 500 x 500 pixel before importing them into AE? I checked file size of those PNG files, and non-cropped single 1000×1000 pixel PNG is 15 KB, but cropped single 500×500 pixel PNG is 7 KB. It’s a big difference.
    I thought I don’t need to crop my image, because I put them into 500 x 500 pixel composition, it means AE won’t render all area of those PNGs, and those PNG images are covered with transparent areas, like a PNG file below.(I uploaded this image to explain my situation, but I am not editing it. I am editing hand drawing images.)
    Though I don’t render all area, pixel size and Alpha data of PNGs has some effect on rendering time in AE? If so, I should have cropped…
    Please tell me what is the best choice to render fast in AE while editing. Thank you in advance.
    Vishesh Arora replied 13 years, 7 months ago 3 Members · 4 Replies
  • Vishesh Arora
    January 30, 2013 at 7:18 am
    Yousuke
    The PNG that you have uploaded does not contain the Alpha Channel.
    I would suggest you to import the PNG sequence in AE , put that sequence in 500 x 500 comp and Pre-Render it and then Work on the effects part.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Tudor “ted” jelescu
    January 30, 2013 at 10:23 am
    I would crop only if I knew that I do not want to change things later (re-size or move). Vishesh suggested a method or you can do it in PSD. However, at the size you are working with it will not make that much of a difference in AE on a decent machine. You will notice a difference at larger sizes (for example if you crop a 4k image to HD…)
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Yousuke Tadokoro
    January 31, 2013 at 9:17 am
    Thank you for your reply guys. That PNG has no alpha? Sorry.
    If there is no difference in rendering time, I won’t crop it.
  • Vishesh Arora
    January 31, 2013 at 9:18 am
    Glad to help
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
