Activity › Forums › Adobe Premiere Pro › Should I convert AVCHD .mts to Pro Res QT?
  • Should I convert AVCHD .mts to Pro Res QT?
    Posted by Zach Meissner on January 12, 2012 at 3:09 pm
    I have more than an ample machine to power through 1080 24p AVCHD 24mbits from a GH2 camera – dual 6 core Xeon Mac with Quadro 4000 card. But i’m wondering is there any advantage to converting to pro res before i begin my editing in premiere?
    The file size nearly quadruples when going to Pro Res LT from the MTS file, so is there any advantage to doing this in the editing process other than converting the frame rate to 29.97 during the conversion?
    http://www.lab316.com
    Rich Rubasch replied 14 years, 8 months ago 3 Members · 4 Replies
  • Tom Daigon
    January 12, 2012 at 3:19 pm
    If your computer can handle AVCHD, then with Premiere there is not advantage to converting to Prores. Thats more a FCP workflow.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Zach Meissner
    January 12, 2012 at 3:26 pm
    Thanks for the fast reply Tom!
    So just checking myself here. I’m editing all the 24p clips in 24p avchd timelines. This is going to TV so am I correct in my process of dropping the final edits 24p timeline into a 29.97 timeline and exporting from there?
  • Tom Daigon
    January 12, 2012 at 6:02 pm
    I would check with the tv stations about their requirements. Never assume anything. You might not have to convert at all. Conversions can mess things up visually depending on how they are down.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Rich Rubasch
    January 12, 2012 at 6:16 pm
    Also I am curious if the native AVCHD retains the recorded timecode or if each clip will start at 00:00. If you convert to ProRes I am guessing you will get the timecode from the metadata…anyone concur?
    You will need to do a 23.98 to 29.97 transcode for the stations. No station can accept 23.98 spots. Episode on the Mac does a good job with frame rate conversions and you might have to test the Premier Encoder.
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
