Activity Forums Blackmagic Design Should I be worried?
  • Should I be worried?
    Posted by David Mack on November 12, 2007 at 9:58 am
    I use Multibridge Extreme using the DVI-D to an LCD monitor to view my video output. I turned on my MBE this morning but instead of getting my desktop showing on the video monitor, I got a scrambled signal, as if the monitor couldn’t handle the refresh. I fired up Premiere CS3 to see if video from the MBE might work – no change. I powered the system down, waited a bit and then booted back up – Same issue again. I connected a PC up the the monitor to check that it wasn’t the monitor at fault – it wasn’t. I turned the system off and put the composite output from MBE to the monitor and powered the system back up. The monitor was still set to receive a DVI-D input. To my surprise, the DVI-D worked fine?!?!?!?! So, now I’m left feeling that my MBE might be breaking down? Kristian – any explanations? Does this mean my system IS faulty?
    David Mack replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
