Activity › Forums › VEGAS Pro › should i be using .mov lossless???
  • should i be using .mov lossless???
    Posted by Kutterup on June 21, 2005 at 12:38 pm
    ok i have buddy that needs to give me some files for re-editing. i work on a pc using vegas and after effects (i go back and forth alot between the two programs).
    now my friend works on a mac and he has footage from imoive and FCP.
    now my question is should he give me the footage as .mov or .mov lossless?
    when i was in school we worked on macs and i was always told to simply keep everything in quicktime formatt but then i come to learn about lossless and like i said before i go back and forth between my NLE and AE (i mean a lot). so should i always make sure im using a lossless or is simply having a .mov good enough??
    sorry if i sound stupid 🙂
    Chris Borjis replied 21 years, 3 months ago 3 Members · 4 Replies
  • Gary Kleiner
    June 21, 2005 at 3:39 pm
    As always, lossles or uncompressed files can be better quality, but come at the cost of much bigger file sizes. For a large project, this means you may have a storage problem as well as playback problems.
    Why don’t you try out a sample of each and see what you end up with?
    Gary Kleiner
    Vegas Training and Tools.com
  • Chris Borjis
    June 21, 2005 at 4:06 pm
    if it helps, Quicktime ANIMATION & PNG are both lossless codecs
    visually but not uncompressed. PNG files will be
    much smaller than ANIMATION but will take longer
    to render.
    lots of folks use PNG for this reason.
  • Kutterup
    June 22, 2005 at 3:29 am
    so can i render out PNG in vegas and it does add compression right? because i dont want to lose anything as i go in and out of the programs alot.
  • Chris Borjis
    June 22, 2005 at 4:41 pm
    I just tried this with Vegas4 and it does indeed work.
    the quality will be lossless meaning you won’t lose
    any quality.
    just as good as uncompressed but smaller file sizes.
