Activity Forums Canon DSLR Cameras Should a 24-105 lens image stabilization be audible?
  • Should a 24-105 lens image stabilization be audible?
    Posted by Bob Cole on February 3, 2012 at 6:48 pm
    I’m testing a used 24-105mm L IS Canon lens. When I put my Canon 60D in Movie mode, and the lens in Stabilizer On, the motor makes a continuous sound. It’s the same sound that is made when the camera is in still-image mode and you depress the shutter halfway. But when the camera is in still-image mode, the IS motor is only on briefly, while the shutter is being pressed. In Movie mode, the grinding sound is continuous (which makes sense, but still – it makes me wonder whether there is “wear and tear” happening).
    My question is: should the IS on this lens be this audible? Does continual IS action create a maintenance issue with these lenses? The “kit lens” that came with the camera (18-135mm) is not nearly so noisy in comparison.
    Thanks.
    Bob C
    Bob Cole replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
