Activity Forums Apple Final Cut Pro Shots on timeline changing…
  • Shots on timeline changing…
    Posted by Jason Porthouse on March 21, 2012 at 10:03 am
    …without any input from me!
    I’m cutting a series of films from one event (maybe 80-100 hours of source material) and all’s going well – each film is a project and they’re between 1-5 mins long. Twice now my client has gone to view projects and the edits we’ve done have changed – specifically shots on the timeline (1 in each case) have extended from their original duration (about a second in each case) to the full length of the source shot – maybe a couple of minutes or more. Fortunately the rest of the edit still exists, just away down the end of the timeline.
    This has happened with no input from me or the client, and is a little worrying – anyone experienced this before? Is there a way to stop it? Does this signal worse to come? Are we all doomed?
    As ever the collective knowledge of this pasture’s members will be gratefully received!
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
    Jason Porthouse replied 14 years, 6 months ago 3 Members · 6 Replies
  • Richard Herd
    March 21, 2012 at 4:11 pm
    Yes, we are all doomed, but X has nothing to do with it.
    Can you explain a bit more how you have your project arranged? Is it compound clip’d or is it clips in the project timeline?
    In either case, what happened when you trimmed the offending clip to its proper length?
  • Jason Porthouse
    March 22, 2012 at 9:31 am
    Hi Richard,
    No, they were just clips in the primary storyline. One clip in each project (2 of about 15) had simply extended itself to it’s full length, just as if you’d done it manually. I did wonder if I (or my client) had accidentally stumbled across a key combination or obscure shortcut that ‘replaced clip with entire original’ or ‘extend clip to it’s fullest extent’ but no…
    No damage was done to the edit as the clips post this offending one were intact, just a few minutes down the timeline. It took me all of a couple of minutes to fix, so no biggie, but puzzling and a little worrying nonetheless.
    Jason
  • Chris Northcross
    March 22, 2012 at 2:46 pm
    Have you been able to re-create this in any other project?
    Whether you believe that you can or you can’t, you’re absolutely right.
  • Jason Porthouse
    March 22, 2012 at 5:43 pm
    No Chris, I haven’t had a repeat of it so far. I’ll keep a weather eye out though…
  • Richard Herd
    March 22, 2012 at 7:46 pm
    Did you change the frame rate of the project?
    https://help.apple.com/finalcutpro/mac/10.0.3/#ver3363b44e
  • Jason Porthouse
    March 23, 2012 at 10:34 am
    No, nothing like that. The projects were fine, the machine was shut down, and on restarting and opening FCPX they’d changed. I’m assuming some kind of database corruption/glitch…
