Activity Forums Apple Final Cut Pro Legacy Shotput Pro vs. L&T disc image
  • Shotput Pro vs. L&T disc image
    Posted by Ron Craig on December 7, 2010 at 7:02 pm
    I have been considering buying Shotput Pro to backup memory cards after they come out of the cameras. But I’m wondering if the copies made by Shotput Pro are any better than the disk images that I’ve been creating with FCP’s Log & Transfer window. Any thoughts?
    I do understand that Shotput Pro might be better than using the Finder to do copies because of its file verification function. But I’m not yet convinced that Shoput Pro’s results are better than making disc images.
    The fact that Shotput Pro can make simultaneous copies to multiple drives is definitely cool. But fidelity of copies is the more important issue to me.
    Ron Craig replied 15 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    December 7, 2010 at 7:23 pm
    [Ron Craig] “But I’m wondering if the copies made by Shotput Pro are any better than the disk images that I’ve been creating with FCP’s Log & Transfer window. Any thoughts?”
    Better? No. But Shotput Pro does a file verification…to make sure that EVERYTHING has been copied over. And it automates the making of folders to offload the cards, and automates the naming process. Plus, you now have the full card structure with a folder…so you can import right away. Disk Images need to be un-imaged in order to work, no? And then do they have a unique reel name, or are they NO NAME?
    [Ron Craig] “But I’m not yet convinced that Shoput Pro’s results are better than making disc images.”
    Shotput can copy one card to up to three locations all at once. So you can pop in the card, and press a button, and walk away as ShotPut does the rest…makes a folder, names it, copies the card…to two locations. So you can run back to the station, pop in the card, click a button, and get back to shooting. Less time spent managing the offload.
    [Ron Craig] “But fidelity of copies is the more important issue to me.”
    If you drag via the finder…make a disk image…or use ShotPut Pro…they all will be the same. None of those options degrades the image in any way. It is just a data transfer…a copying process.
    Shane
  • Ron Craig
    December 8, 2010 at 3:51 pm
    Thanks for that, Shane. And for your tutorial on tapeless workflows. (I’ve been tapeless for a while and learning on my own but I did pick up a couple of interesting new facts from that tutorial.)
    As for file verification by Shotput, that’s certainly a plus. I’ve never had a problem with disk image creation in FCP or just using the Finder, but given that errors are certainly possible, file verification could be extremely important in a very small number of cases.
    I’ll look at Shotput for that and for the simultaneous copying functions, which could keep me from having to leave the bar downstairs after a shoot day in order to get back up to the hotel room to switch out hard drives so often…
