Activity › Forums › Panasonic Cameras › Shotgun mic with pan dvx 100b
  • Shotgun mic with pan dvx 100b
    Posted by Aholder18 on June 8, 2007 at 10:08 pm
    hi,
    so i just got a at897 audio technica shotgun mic for my panasonic dvx 100b. I’m not sure that i am working it properly.
    The steps i have taken :
    mount the mic with fresh battery inside.
    hook up to input 1 with xlr cable
    Place channel 1 select (button under LCD screen) on input 1
    PLace channel 2 select on INT
    Made certain input 1 button was on the on switch
    Made certain input 2 button was on off switch
    I shot a few thigns around the house with the shotgun mic pointed at it, and when i played it back on my camera it didnt sound a whole lot different or with more clarity than before with the internal microphone.
    What gives?
    Will i only be able to hear a difference from a monitor other than camera playback?
    please help
    thanks
    -Anthony
    Tim Scarpino replied 19 years, 3 months ago 3 Members · 5 Replies
  • Tom Maloney
    June 11, 2007 at 10:22 am
    Mis givings people have about a shotgun, what did you shoot around the house ? people talking ? the closeer the mic to the audio source the better the sound. Shotguns do really not work good around solid walls floors, too much refelctions. Tell us what you are trying to record. Also get the mic off the camera Always try and get the ic closer to the audio source
    good luck
    Tom
  • Tim Scarpino
    June 11, 2007 at 11:33 am
    When you monitored the playback audio, were you listening to both audio channels or just channel 1?
    Tim Scarpino
  • Aholder18
    June 11, 2007 at 12:11 pm
    Tim,
    I rechecked using my tv as a monitor and speaking right into the at 897, and it worked just fine. I guess i was just wasnt sure what to expect because ive never used one of those mics before, but i definitely heard a good difference. Thanks for your input which propelled me to go back and try it out again. I am going to be shooting and recording sounds at windy baseball games. I purhased a rycote softie for the shotgun mic, do you have any other tips and suggestions. I will be attempting to pick up doc style dialogue as well as sounds from about 20-30 feet away. Is this feasible with the at-897?
    thanks for your time and input again
    -Anthony
  • Aholder18
    June 11, 2007 at 12:13 pm
    AND TOM< THANKS FOR YOUR INPUT AS WELL!!! SORRY - YOU GUYS WERE BOTH EQUALLY HELPFUL!!
  • Tim Scarpino
    June 11, 2007 at 1:33 pm
    Well, 20-30 feets is quite a distance, so don’t be expecting miracles from your SOTs. The closer the better, and of course, keep the mic pointed directly at what you want to capture. And for the wind, I’ve often found fiber scrimming material (used to diffuse lighting) works really well in a pinch to knock down wind noise.
    Finally, you might be able to do some EQ in post to give your subjects a bit more “presence”.
    Good Luck,
    Tim Scarpino
