Activity Forums Adobe Premiere Pro Shot Number Overlay
  • Shot Number Overlay
    Posted by Jason Peterson on May 5, 2016 at 7:14 pm
    Hello helpful community,
    I have encountered a client that wants preview cuts delivered with shot number overlays based on the shots in each particular video instead of a timecode overlay.
    Does anyone know of a way to automate this instead of making titles and trimming them to each cut in the edit? I would be very grateful.
    Chris Gomersall replied 5 years, 1 month ago 4 Members · 6 Replies
  • Oki Pienandoro
    May 20, 2016 at 4:58 am
    Old thread, have you finished the project ?
    You can rename the video files, or clip name according to the shot obviously, then activate the overlay in the monitor (click the wrenchbar thing).
    You can choose the overlay info based on clip name/file name.
    Sorry for the english, not native speaker.
  • Jason Peterson
    May 20, 2016 at 5:38 am
    We are not yet done with the project, but overlaying titles seems like it will be faster than renaming files. Especially since we have more than one editor using the same files.
    Thanks for the idea though.
  • Oki Pienandoro
    May 20, 2016 at 5:54 am
    You didn’t have to rename the files, you can rename the clip instead. It’s faster than manually placing titles.
    I don’t know how you manage the footage, but if we renaming something and press enter, it automatically goes to the next footage below. Making it really easy to rename clip consecutively.
    The benefit would be, if you using the same clip elsewhere, you didn’t have to place title again.
    Although because the project is already ongoing, renaming the clip would not make the overlay appear in the old timeline.
    But you can easily solve this by match frame (F), then you can replace the clip in the timeline with a new clip name with in-out point intact.
    Using shortcut to “replace clip from source”, this can be done much faster than manually placing titles, also you minimize the work need to be done if you trim clip, since the Shot overlay is done automatically.
    Also you can limit the overlay info, say you didn’t want the overlay to show up in the mercury transmit, or in playback.
    But it’s your project, you ultimately decide what’s the best option would be.
    Also you said that the project is being edit by 2 editor, so yeah renaming the files would be a better option.
    That was just my 2 cents.
    Happy editing !
  • Jason Peterson
    May 20, 2016 at 6:46 am
    Thanks. I’ll consider that.
  • Roei Tzoref
    August 6, 2021 at 11:56 am
    I recently had to do that and found a workaround ever since premiere introduced scene detection.
    1. import the master rendered file to premiere
    2. activate scene detection under clip, check create subclips and hit analize
    3. drag all the subclips into the timeline
    4. add clip name and timecode effects with these settings
    5. now you have a timecode + subclip number(shot number) and frame number for each shot.
    6. if you invest in a renamer script in premiere you could rename “subclip” to “shot”
  • Chris Gomersall
    August 6, 2021 at 4:49 pm
    that is genius
