Activity › Forums › Apple Final Cut Pro › Shot Notes X (or other app): notes to clip markers via XML import?
  • Shot Notes X (or other app): notes to clip markers via XML import?
    Posted by James Culbertson on March 7, 2019 at 1:17 am
    Is there a way to make Shot Notes X (or other app) sync a CSV (or other filetype) of log notes by timecode to marker notes in a single clip inside of FCPX?
    David Esp replied 7 years, 4 months ago 2 Members · 3 Replies
  • David Esp
    April 18, 2019 at 8:33 am
    Not sure how to do it for a single clip in Browser, but the following works for a clip in a timeline/sequence/Project (I call it sequenceProject/seqProj). Maybe if you Export XML from a clip selected in Browser? (haven’t tried it – please post any result )
    Suggestion: Cut Notes – Marker Import app (free) from Digital Rebellion
    Scroll down to “Resources” at https://www.digitalrebellion.com/cutnotes/
    Cut Notes format is like this:
    Name Type Marker Name Comment Start Duration Color
    Sequence 1 Sequence Mark 01:00:03:09 00:00:00:00 Red
    Sequence 1 Sequence Mark 01:00:09:03 00:00:00:00 Red
    Sequence 1 Sequence Mark 01:00:14:23 00:00:00:00 Red
    Sequence 1 Sequence Too Quiet Too Loud 01:00:19:11 00:00:00:00 Red
    Sequence 1 Sequence Mark 01:00:26:15 00:00:00:00 Red
    Sequence 1 Sequence End Scene 01:00:28:26 00:00:00:00 Red
    The first 2 columns can stay as above – import tool asks (prompts for) which sequenceProject you want to import the markers to.
    I suggest:
    Duplicate existing sequenceProject
    Export XML for that seqProj
    Using Marker Import app, specify the markers text-file and the XML file
    FCPX should then contain the updated (markers) sequence
    …though it won’t necessarily be selected – do that manually
    Now check your results
    Cut Notes itself (another app) is not needed for this workflow, but it is a cool app too (I have no connection to them except as a customer). I use it or give it to others (including inexperienced) on iPad while making review mark-ups. Could be for shooting live event (self or any reliable assistant) , watching a broadcast/streamed programme or own/client editorial review. Advantages: simplicity (negligible training needed) & domesticity (sit back comfortably on sofa).
  • James Culbertson
    April 21, 2019 at 1:45 am
    Thanks David.
    Turns out that the CommandPost folks had this functionality implemented for generic Excel/CSV files. Copy from excel and paste in FCPX after selecting relevant browser clip.
    They also added a paste markers command (to browser clips) that is specific to Frame.io csv downloads, which is what I was interested in particularly.
  • David Esp
    April 29, 2019 at 8:34 pm
    Thank you for that tip James – I’ll investigate
