Activity Forums Adobe After Effects shot live action, need to create timeplapse from pieces of that video
  • shot live action, need to create timeplapse from pieces of that video
    Posted by Jason Brown on January 14, 2019 at 3:47 pm
    I have a 13 minute video shot that we removed items from a shot and I need to create a timelapse.
    My plan was to do this manually, but I’m wondering if I could set a marker at each frame I want and then build a sequence from markers as still frames?
    Any clever ideas?
    Max Haller replied 7 years, 7 months ago 3 Members · 5 Replies
  • Jason Brown
    January 14, 2019 at 4:46 pm
    camera is perfectly locked
  • Stephen Smith
    January 14, 2019 at 8:22 pm
    Maybe I’m miss understanding what you want to do but here are my thoughts.
    Say you have a 5-minute clip but you need to cut a few sections of that 5 minutes out. Place the video in a pre-comp. Use the split feature to cut the clip and remove the unwanted parts. Make sure the clip doesn’t have holes in it and the clips play one after the other.
    Go back to the main comp and add a speed change to your pre-comp to speed it up so it looks like a timelapse.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Jason Brown
    January 14, 2019 at 10:30 pm
    That’s not what I need. I can manually do this, but I’m looking for a way to automate it.
    I have a stack of coins several hundred and we rolled video with removal of each coin one by one with a clean frame in between each removal. What i want is to grab a frame of each coin where the removal action is not in frame. I can use still frames.
    My thought is to press play – set a marker each time I have a clean frame and then automate a build of a comp grabbing still frames at each marker. Seems like a script that would exist or could easily be written. It’s about 300 frames.
  • Jason Brown
    January 15, 2019 at 2:59 am
    I got it.
    I was hoping for a clever automation, but I went ahead and did in FCPX manually. I just played in 3x speed and set a marker every-time hand exited frame. Then I set a keyboard shortcut for “next marker” that was one key different from “add edit” then just repeated the keystroke 300 times (went ahead and played some music so I could keep rhythm ☺) – select all, set the duration to 1 frame and it worked.
    Thanks.
  • Max Haller
    January 23, 2019 at 4:21 pm
    Something like Quickkeys might have helped you automate that process. It’s just a program that records key presses and plays them back. Your process reminded me of syncing and grouping multicam shots and i used to use Quickkeys to hit all my key presses for me. You’d still have to go thru and place the markers but a key macro program could speed up the process of add edits and next marker shortcuts in the future.
