Activity Forums Apple Final Cut Pro Legacy Shot HD/outputting to DV
  • Shot HD/outputting to DV
    Posted by Robmestas on December 13, 2005 at 3:28 am
    Hello,
    I am having a problem with outputting to my DV camera. I shot with Varicam and captured via 1200A deck. My easy setup was DVCPROHD – 720p24. Now when I edit I change my video output/device control to Firewire DV NTSC. The problem is that the video will not play. The sound plays and I get a still image but the video stands still on firewire output. Is this because the camera is 29.97?
    Do I need to edit in a 23.98 NTSC timbase, if so how do I maintain the 1.85 aspect ratio? When I edit in a NTSC timebase the image is squeezed.
    Thanks.
    Shane Ross replied 20 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    December 13, 2005 at 5:20 am
    You are still working with an HD signal…DVCPRO HD. That signal cannot be output thru a DV (a SD device) and routed to a monitor. The only way to monitor that footage and that timeline is to route thru a 1200HD deck, or route thru a capture card and HD monitor.
    To output that as DV, you need to drop it into a DV sequence and render…THEN output.
    If your footage in the sequence is squeezed, it means that your project does have the ANAMORPHIC box checked.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
