Activity › Forums › Adobe After Effects › Shot clean up
Shot clean up
Posted by Jawad Zafar on August 31, 2016 at 7:33 amHi!
Hope everyone is good.
I am working on a VFX Shot and I need to clean up my shot. In my following shot There is a sign board and I need to remove this sign board.
How can I remove it?
Waiting for response.
Jawad Zafar replied 9 years, 12 months ago 2 Members · 3 Replies -
Jawad Zafar
September 1, 2016 at 8:14 amHi Dave LaRonde!
Thanks a lot for your guidance.
Let me tell you my scenario and requirement in detail.
After cleaning this sign board out I am going to add same kind of another 3D Sign board which will be animating like zero gravity applied and all parts are flying up.
So this area will be covered with another sign board.
and I already have created a clean version of this area in Photoshop successfully.
Now I just have to put that clean plate in the area of board. And want to know how to do it.
I did 3D tracking of whole scene then I added clean plane by camera projection on 2 3D planes. but when camera rotates or move to other side. That projection get stretched. I tried mocha to clean this shot but After cleaning it was showing sharp edges.
Are there any ways If I can apply multiple techniques in different angles of videos to achieve desired shot. If we can trick Audience?
You are most welcome to provide me professional and all level or suggestions.
I will be very thank full.
Tero Ahlfors
September 1, 2016 at 9:01 amThe biggest problem here is the parallax. The sign is moving differently than the fence and the fence is moving differently than the field and the field is moving differently than the buildings in the background. You can’t deal with that using a single 2D clean plate. You should test the footage with the sign you’re trying to put in the scene and look what you’d need to clean.
Jawad Zafar
September 1, 2016 at 9:16 amThanks a lot Tero Ahlfors!
I will try your suggestion.
