Activity Forums Apple Final Cut Pro Legacy Shot anamorphic by mistake…
  • Shot anamorphic by mistake…
    Posted by David Eells on June 13, 2005 at 8:22 pm
    and the extra width is unneeded. What I’d like to do is convert from anamorphic to non-anamorphic, giving up the extra width – it’s all tight headshots. Is there an easy way to do this?
    David Eells replied 21 years, 2 months ago 2 Members · 2 Replies
  • Bret Williams
    June 13, 2005 at 9:50 pm
    Anamorphic is generally not extra width, but actually less height. Unless you’ve got a very expensive camera. It actually uses less of your CCD, the center 16:9 part, and then stretches it vertically to fit the 4:3 ratio.
    But either way, just make sure you tag it as 16:9 footage and drop it in your non 16:9 sequence. Scale it up until it crops out the “extra width.”
  • David Eells
    June 16, 2005 at 11:07 am
    Thanks, Bret. I didn’t realize that’s how “widescreen” was handled.
    Bud
